Advise with Mojo
Mike Leisegang
Advise with Mojo
on Jun 16, 2004 at 6:38:08 pm
Would appreciate some advice.
My system
Intel D875 PBZ MAINSBOARD
Intel P4 3,06 Hyperthreading processor
Gainward FX5950 ulta 256 graphics card.
Seagate internal SATA drives
2 Gig onboard mem
Win Xp Pro on 20 gig ATA drive.
Avid Express Pro on 20 gig ATA drive
Media on a 200 gig Seagate SATA drive.
Question is....
Will I be able to use the Avid Mojo with this system with a Lacey Firewire PCI card or card recommeded in this forum.
I will not be using any external drives etc or other firewire hardware.
Best regards,
Trondstill
Gary Bettan
Re: Advise with Mojo
on Jun 17, 2004 at 12:41:50 am
As long as the firewire card has the TI chipset you'll do great. Avid recommends the ADS Pyro PCI 64 card. It's a little more then a generic card $50), but the results are always outstanding.
http://www.videoguys.com/pyro.htm
Gary
Videoguys.com / The Electronic Mailbox 800 323-2325
We Are The Desk Top Video Editing & Production Experts
All DTV purchases come with our exclusive 30 day customer assurance program and FREE Tech Support
Mike Leisegang
on Jun 17, 2004 at 6:25:19 pm
Hi Gary,
Thank you for this info.
One more question if I may.
I presume I will not be able to use external firewire hard drives at the same time with the Mojo and the system spec's above.
Is this correct.
Best regards
Trondstill.
Jon Oransky
on Jun 21, 2004 at 2:52:07 pm
You will need a second PCI firewire card to connect the external firewire drive to.
- Jon
800-323-2325 x120
Mike Leisegang
on Jun 23, 2004 at 3:33:09 pm
Hi Jon,
Are you saying that I can use the Avid Mojo on one firewire card then external drives on another firewire card with the system specs above.
I thought Avid Mojo could only run on systems with segmented bus's.
Mojo can only be used on it's own if one has a board without segmented bus's.( ie no further firewire outputs )
Thank you for your reply.
Trondstill.
