200 gig drive only shows 127gigs
oosal
on Apr 21, 2004 at 2:11:11 pm
I have a new 200 gig maxtor ide drive i am installing, but its only showing me 127 gigs. Whats the deal
John Q
Re: 200 gig drive only shows 127gigs
on Apr 22, 2004 at 1:59:22 am
Can you say bios limitation. In order to access the full 200 GB, you'll either need to load a bios extender program that's usually bundled with the drive, or buy a PCI controller that loads its own extended bios, or a new motherboard. I also believe that this will only work on Windows XP with SP1 installed.
You can read about it at http://www.pcworld.com/news/article/0,aid,53824,00.asp
D_
by
on Apr 24, 2004 at 12:22:41 am
You could also partition your drive into two smaller drives, say a 120GB and a 60GB if you don't want to upgrade to XP or can't find the BIOS update...
Dylan
<[color>EDIT!] I must have been sleeping when I wrote this post! And nobody caught me. If the BIOS can only see 127 GB, you cannot magically format the drive into 120 and 60. It just doesn't work that way! Without a BIOS upgrade, you are stuck with the smaller drive. Or, you could get an external drive case and plug your drive in that way. However, you will be limited in throughput speed.
Dylan
