Problems with 1394 connections
DigitalDoyle
on Mar 15, 2004 at 10:33:09 pm
Hi There!
I used Jon's specs here on the site as the basis for my new NLE (thanks Jon!). I love the machine and it's been working flawlessly up to this point.
I built this machine to supplement my other NLE which is slower than the new one. I've been able to edit video in PPro and burn DVDs in Encore with no problems. Works great! However, I hadn't yet tried to capture video from my DV cams, and when I tried this morning I found that I couldn't get any connection at all to the 1394 ports. The USB ports all work perfectly.
I tried both the front and back 1394 ports but got no response from either my old Sony DCR-VX1000 DV cam or the new Panasonic PV-DV953. I also have a Maxtor 250Gb One Touch external drive that has both 1394 and USB connectivity that I brought over and tried too connect to the new machine via 1394, but it wouldn't see it either.
I checked the BIOS and the 1394 option is definitey enabled there. I also cracked the case and double-checked all the connections and they were all as they should be. I also checked the Device Manager and could not see any 1394 devices there.
Does anybody have any insight as to what the problem might be? I'd greatly appreciate it!
Thanks much!
System Specs: Antec Sonata Case, ASUS P4C800-E Deluxe motherboard, PNY Quadro4 NVS 64mb graphics card, Intel P4 2.8Ghz processor, 2x512Mb Corsair PC-3200 RAM, Western Digital 60Gb 7200rpm System Drive, 2x160gb 7200rpm Seagate SATA video drives, 2x160 7200rpm Seagate ATA video drives, Sony DRU-530A DVD+-RW,+-R DVD writer, Microsoft WinXP Pro OEM OS.
Doyle Calvert
http://www.digitaldoyle.com
DigitalDoyle
Re: Problems with 1394 connections
on Mar 16, 2004 at 12:37:11 am
Whoops! My motherboard is a ASUS P4C800 Deluxe. NOT the P4C800-E Deluxe listed previously. Not sure if that makes any difference, but it might.
Thanks.
Doyle Calvert
Goodspeed
on Mar 16, 2004 at 1:27:57 am
I have the same motherboard and have had no problems with my 1394.
The 1394 port is part if the motherboard and uses a VIA chip.
I checked the VIA site and it states that XP should have detected and installed the drivers automatically.
http://www.viaarena.com/?PageID=3&faq=8&Search=
I would try to reinstall the 1394 drivers through the control panel and if that doesn't work, exchange/return the motherboard for a new one.
DigitalDoyle
on Mar 16, 2004 at 2:19:35 am
Thanks for the info, GoodSpeed! Much appreciated!
Doyle Calvert
DigitalDoyle
on Mar 16, 2004 at 3:32:04 am
I wasn't able to even get XP to recognize the 1394 hardware on the motherboard. I did some research and discovered that the problem I'm having is fairly common, but that there doesn't seem to be any real solution, other than buying a simple firewire card.
The firewire connectivity is the only thing I'm having problems with. Otherwise this machine rocks. So I simply disabled 1394 in the BIOS and will pick up a firewire card tomorrow and be done with it.
Doyle Calvert
