NLE System built for Matrox RTX100/Pinnacle DV500
videocrafter
on Mar 11, 2004 at 12:21:13 am
Okay, here's the NLE DIY system I built (a little over Jon's budget but worth it! Thanks Jon for the guidelines. See it live on cam at: http://www.videocrafter.com/webcam.html
Total Cost: $1,655.70
All parts were purchased at newegg.com
Total Shipping was was only $17.99
I'm totally blown away by this system. I built it to run Matrox RTX100 but since I don't have enough money left to purchase the Matrox at this time, I installed my old Pinnacle DV500 card with Adobe 6.0 and it is running flawlessly, not a single dropped frame after capturing over 100 GB thus far! This systems has yet to crash (knock on wood)! The main thing I learned, if your going to enable the "case open alarm function" close the case before trying to boot the system. I kept getting a "CPU fan failed" alarm. The CPU fas was in fact running, but I guess the MB just didn't have a message saying "close the case stupid" :-(
Parts:
Case: $175.00 (Just the coolest case ever!)
Make: Thermaltake Black Xaser V Damier Full-Tower Case with 420W Power Supply, Model "V5420AU"
Purchased from: http://www.newegg.com Item # N82E16811133125
http://www.newegg.com/app/viewProductDesc.asp?description=11-133-125&de...
Specifications:
Case Type: Modern Tower -Xaser V Damier
Color: Black
Material: 1.0 mm SECC Chassis, Aluminum made Front door
Drive Bays: External 5 x 5.25" - 2 x 3.5" Internal 3 x 3.5"
Expansion Slots: 7
Front Ports: Dual USB2.0 & IEEE1934 fire wire in front
Power Supply: 420W Power Supply
Cooling System: 2x 80mm (see pics), 3x 90mm
Dimensions: (LxWxH) 17" x 7.5" x 21"
Special Features: 4 channel VR fan speed controllers, Digital LCD monitor with blue back lighting
Motherboard:$178.99
Make: ASUS 875P Chipset Motherboard for Intel Socket 478 CPU, Model "P4C800-E DELUXE"
ASUS web site: http://www.asus.com/prog/spec.asp?m=P4C800-E%20Deluxe&langs=01
Purchased from http://www.newegg.com Item # N82E16813131464
Neweggs Description Link: http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-464&de...
Specifications:
Supported CPU: Socket 478 Pentium 4(HT)/Celeron Processors
Chipset: Intel 875P + ICH5R
FSB: 800/533/400MHz
RAM: 4x DIMM support DDR400/333/266 Max 4GB
IDE: 2x UltraDMA 100, 1x UltraDMA 133(from Promise 20378) up to 6 Devices
Slots: 1x AGP Pro/8X, 5x PCI, 1x Wi-Fi
Ports: 2xPS2,1xCOM,1xLPT,1xSPDIF Out,1xLAN,2x1394(Rear 1),8xUSB2.0(Rear 4),Audio Ports
Onboard Audio: AD1985 6-Channel Codec
Onboard LAN: Intel 82547EI GbE
Onboard SATA/RAID: ICH5R, 2x SATA, RAID 0/1; Promise 20378, 2x SATA, RAID 0/1/0+1/Multiple RAID
Onboard 1394: VIA 1394 chip
Form Factor: ATX
CPU/Processor: $227.00
Make: Intel Pentium 4/ 3.0C GHz 800MHz FSB, 512KB L2 Cache, Hyper Threading Technology Model# BX80532PG3000D
Intel's web site: http://www.intel.com/products/desktop/processors/pentium4/index.htm?iid=ipp...
Purchased from http://www.newegg.com Item # N82E16819116156
Neweggs Description Link: http://www.newegg.com/app/viewProductDesc.asp?description=19-116-156&de...
Specification
Model: Intel Pentium 4 3.0C w/ Hyper Threading
Core: Northwood
Operating Frequency: 3.0GHz
FSB: 800MHz
Cache: L1/12K+8K; L2/512K
Voltage: 1.525V
Process: 0.13Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2
Warranty: 3-year MFG
Packaging: Retail box (with Heatsink and Fan)
Memory: $168.00 (2 x 512MB Sticks @ $84.00 ea)
Make: Kingston 184 Pin 512MB DDR PC-3200 Model# KVR400X64C3A/512
Purchased from http://www.newegg.com Item # N82E16820141424
Neweggs Description Link: http://www.newegg.com/app/viewProductDesc.asp?description=20-141-424&de...
Specification
Manufacturer: Kingston
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3-3-3
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime
System Drive: $105.00 - 120GB SATA
Make: Maxtor 120GB 7200RPM SATA Hard Drive, MODEL 6Y120M0, OEM Drive Only
Maxtor's web site: http://www.maxtor.com/en/support/products/ata/desktop/diamondmax_plus_9/ind...
Purchased from http://www.newegg.com Item # N82E16822144319
Neweggs Description Link: http://www.newegg.com/app/ViewProductDesc.asp?description=22-144-319&de...
Specifications:
Capacity: 120GB
Average Seek Time: 9.3 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: Serial ATA
Features: FDB Motors
Manufacturer Warranty: 3 years
Remark: OEM Drive Only
Video Drive #1: $225.00 - 250GB SATA
Make: Maxtor 250GB 7200RPM SATA Hard Drive, Model 7Y250M0, OEM Drive Only
Purchased from http://www.newegg.com Item # N82E16822144327
Neweggs Description Link: http://www.newegg.com/app/viewProductDesc.asp?description=22-144-327&de...
Specifications:
Capacity: 250GB
Average Seek Time: 9 ms
Buffer: 8MB
Features: S.M.A.R.T. compliance features
Operating System: Windows XP Pro :$138.00
Make: Microsoft Windows XP Professional with Service Pack SP1a - Full Version OEM
Microsoft's web site: http://www.microsoft.com/
Purchased from http://www.newegg.com Item # N82E16837102143
Neweggs Description Link: http://www.newegg.com/app/viewProductDesc.asp?description=37-102-143&de...
Designed for reliability, security and privacy, high performance, and ease of use, the Windows XP operating system provides a host of benefits for business and home users. A clean and simple desktop, rock-solid reliability, and easy-to-use features that take advantage of the digital age all contribute to the value of Windows XP. *Must be Purchased with Hardware!!*
Graphics Card $168.00
Make: PNY nVIDIA Quadro4 280NVS Video Card, 64MB DDR, LFH, 8X AGP, Model "VCQ4280NVS-PB"
PNY's web site: http://www.pny.com/products/quadro/nvs/280Nvs.asp
Purchased from http://www.newegg.com Item # N82E16814133060
Neweggs Description Link: http://www.newegg.com/app/viewProductDesc.asp?description=14-133-060&de...
Specifications:
Chipset/Core Speed: nVIDIA Quadro4 NVS 200/Not Specified
Memory/Effective Speed: 64MB DDR/Not Specified
BUS: AGP 1X/2X/4X/8X
Ports: LFH(Use Cable to DUAL DVI or VGA)
Support 3D API: DirectX®, OpenGL®
Cable/Accessories: LFH to Dual VGA (Y-adapter) Cable, Driver CD, Manual
Max Resolution@32bit Color: 2048X1536@75Hz
Retail Box (See pics for details)
CDROM/DVD Burner $177.00
Make: Plextor Black 8X DVD-RW/+RW Drive, Model PX-708A/SW-BL
Plextors web site: http://www.plextor.com/english/products/708A.html
Purchased from http://www.newegg.com Item # N82E16827131311
Neweggs Description Link: http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-311&de...
Specifications:
Model: PX-708A/SW-B
Write Speed: 40X CD-R, 24X CD-RW, 8X DVD+R, 4X DVD-R, 4X DVD+RW, 2X DVD-RW
Read Speed: 40X CD-ROM/CD-R, 12X DVD-ROM
Interface: Internal IDE
Buffer: 2 MB
OS Support: Windows XP/ ME/ 2000/ 98SE
Features: Lossless linking technology, Buffer Underrun Proof technology
Remark: Retail Pack (see pictures for details)
Links to reviews of the ASUS P4C800-E Deluxe Motherboard:
Difference between the P4C800 Deluxe and P4C800-E: http://www.anandtech.com/mb/showdoc.html?i=1851
Jon Oransky
Re: NLE System built for Matrox RTX100/Pinnacle DV
on Mar 11, 2004 at 3:54:38 pm
great looking system! i love the case :)
- Jon
http://www.videoguys.com
800-323-2325 x120
RRLech
on Mar 12, 2004 at 9:30:12 pm
Wow! I built a system 6 months ago that is practically your system's twin. Different video card and case, otherwise virtually identical. (Your case may be cooler, though. I have a 420w Antec full tower). I, too, used newegg.com. Excellent site.
I have had the same reliability with mine. Rock solid.
videocrafter
on Mar 12, 2004 at 10:16:02 pm
RRLech, what video card did you install in your system. What NLE software/hardware do you use? P.S. Im sure your case is cool too! :-)
RRLech
on Mar 16, 2004 at 7:45:01 pm
I installed a VGA ASUS V9520TD GeforceFX5200128M video card.
I also use Adobe Premiere 6.0 and a DV500.
I'm actually perfectly happy with my case.
The great thing about building your own system is that you know exactly what you're getting (assuming that you have done your homework).
