Dual P4 MotherBoard - Does someone make a dual P4
Marc C
on Feb 20, 2004 at 8:51:12 pm
Does someone make a dual P4 motherboard?
Also it needs to be something that is upgradable and
can support a Canopus DV Storm2 Card
John Q
Re: Dual P4 MotherBoard - Does someone make a dual
on Feb 21, 2004 at 1:58:16 am
No. Multiprocessor Intel cpu motherboards use a special chipset and a special version of the P4 called Xeon.
Marc C
on Feb 21, 2004 at 4:33:51 am
Tyan and others make a Dual Processor mother board. I have a board for PIII and i am currently running Dual 700's. I saw the one for the Xeon but they only go up to a 2.1MHZ processor and I want the fastest out there...
So what is out there or is the Xeon 2.1 the same speed as the P4 hyperthreading CPU.
Marc
John Q
on Feb 22, 2004 at 12:41:25 am
The Xeon is usually one step behind the latest Pentium core. If you buy a hyperthreading Pentium4, you actually will have similar performance to a dual Xeon system with an OS and applications that support it, like Windows XP Pro and Adobe Premiere Pro. XP Pro wil actually report that you have a dual processor system, since you do have two independent integer units with the HT P4. I'd go with the single fast P4 myself.
BYO_Bliss
on Jun 1, 2004 at 7:05:16 pm
I concur.
if large file IO and serious multitasking (ADD issues, anyone?) are your thing, the dual proc Mobos can have better bus throughput via PCI-X, scsi u320, gigalan, etc. Then it's worth serious consideration of a building a 24x7 workstation (dual).
http://www.tomshardware.com/motherboard/20040514/e7505-chipsatz-12.html
Toms hardware did a recent review of "dual xeons" - but they didn't show the real-world benefits of IO and multitasking. Just single app comparisons, which were only marginally better. so I agree P4 with memory and drives to support will do great for most applications.
