Recommend a DV capture card that works in Linux?
chadjg
on Feb 4, 2004 at 11:00:01 pm
Hello,
Can you all recommend a PCI DV adapter or a PCI capture card that will take a Firewire/1394 input that has good support in Linux?
Basically, my project is to build a cheap machine that does nothing but catprue DV footage to a hard drive and then spit it back out over a Firewire connection, or possibly ethernet.
Any advice? No sense in buying a board I can't get drivers for! And, in case it isn't already obvious, cheapness is goodness.
mojohand
Re: Recommend a DV capture card that works in Linu
on Aug 27, 2004 at 1:49:04 am
Linux isn't all that cutting edge when it comes to DV. I've used 1394 in Redhat with no problems but windows is a lot easier with more options.
