Audio capture problems - help much appreciated
annehe
on Nov 8, 2004 at 12:38:02 am
Hi
We are having major problems capturing audio.
When we play back the tape via TV or through headphones we can hear all audio. When we try to capture, we hear only audio recorded through the camera mic. Nothing from the add on mic.
We use a Canon XL1S camera with mic adaptor, DV Storm pro capture card and Premier Pro 1.5
We operate on XP and have enough hard drive and memory to run a small space station. Any help would be much appreciated.
D_
Re: Audio capture problems - help much appreciated
by
on Nov 8, 2004 at 1:24:10 am
Not sure how you set up your two mics. I am guessing that you used the Stereo2 Input.
Depending on your system capture utility, you may need to select Ch2 Audio and capture it in a separate pass.
If your utility can capture both channels simultaneously, you will have to set that option.
Note, you can only have one audio track in the basic DV format, the second audio track will have to be a separate .avi or .wav file and added to your timeline for editing.
Hope this helps.
Cheers,
Dylan
D_
by
on Nov 8, 2004 at 1:26:19 am
Check out this page: XL1 Audo Info
