Dv Capture Probs
hellopaul
Dv Capture Probs
on Jan 28, 2004 at 12:30:15 pm
Hi all, not sure if this is the right forum to put this in so sorry if its the wrong one. Hopoe you guys will be able to help us out here. I am using a Matrox matrox X.100 Xtremes using premiere 6.5 with jvc br-dv600ea and br-dv600e dv decks. Also using a fresh windows xp install with service pack one. When capturing dv video in premiere with the br-dv600ea deck it does not respond well to the shttle function on the capture screen. It crashes very quick and you have to reset the deck again for it to work. The br-dv600e does respond better. Any ideas on what the problem could be. Its only xp and premiere that is run on the machines
can anyone help me
hellopaul
Re: Dv Capture Probs
on Jan 29, 2004 at 11:23:28 am
update for anyone that can help.
the jvc br-dv600e deck responds perfect but the jvc br-dv600ea just keeps crashing. Do you think their is a compatibility problems with the deck and xp. The deck has worked perfect before. But that was running in win nt.
