Dual monitors/frequency error
COW Forums : Tech Talk
on Oct 20, 2004 at 3:49:30 pm
I am running dual monitors, and it works fine with premiere pro, but the minute i try to run another app i get the message hv frequency to high. Its a a70f viewsonic monitor that is having the problem. I am running it at the highest resolution it will go, and only 60 hz. Anyone have any ideas on this. I dont get the message on my vpr matrix monitor. I am running a gforce card, i think the 5600 128 megs of ram model.
Re: Dual monitors/frequency error
on Oct 20, 2004 at 9:57:58 pm
I had a problem that sounds similar to yours so I'll attempt to recreate what I did...
Is this error a monitor error or an O/S error? (Mine was a monitor error).
Did you try reducing the color depth from 32 bit to 24 bit? Also try reducing the resolution once to see if the problem goes away.
My problem was solved by changing the output frequency. But mine stabilized at 60Hz...
I really don't know what is wrong with your screen, but I hope that something here helps...Sorry I couldn't be of more assistance.
© 2018 All Rights Reserved
