Is there a way to test fps in premiere 7?
captainamerica77
on Sep 16, 2004 at 9:32:35 pm
I am looking and not finding anyway to test what fps I am getting while using premiere 7 is there any seperate program that can do this?
Thank
D_
Re: Is there a way to test fps in premiere 7?
by
on Sep 17, 2004 at 2:39:52 am
fps? Do you mean refresh rate on your monitor? The actual frame rate in your avi?
captainamerica77
on Sep 17, 2004 at 4:13:33 am
opps sorry for not explaining. Want to test the frames per second that my pc is getting when it is exporting the video.
Is that possible?
thanks for the input
D_
by
on Sep 17, 2004 at 11:30:26 pm
Captain, I still don't follow. Will you be recording the video directly from the monitor?!? If you are outputting via an external TV you will get either PAL or NTSC signal refresh rate. But it sounds like you want to output from the PC signal, correct? I am not confident that I can help you here. I can set the refresh rate of the monitor via the display driver, but I do not know if the computer then changes the amount of information transmitted from a video app. Not even sure how you would test that.
Can anyone else help?
captainamerica77
on Sep 18, 2004 at 5:04:06 am
sorry not sure I can explain this any simpler. I am not asking anything to do with monitors.
Frames Per Second that my computer renders while exporting the video.
I capture the video then edit it then when It is exporting it.
I am wanting to know if there is anyway to actually know how many frames per second of video my computer is processing.
nothing to do with monitor refresh rates.
thanks for trying to help.
D_
by
on Sep 18, 2004 at 7:42:46 am
Oh, I get it. You want to know how many frames per second the computer is processing as it renders. I don't know the technical details, but it seems that this depends on the data in each frame. Only the software that is performing the render would know and I do not see that listed as an option in any of the software that I have here. Sorry for not comprehending at first. And worse yet for not being able to answer your question.
Kenneth Daves
on Sep 18, 2004 at 11:31:24 am
Of course, the way to get a rough estimate is to time the output and then divide it into the length of the video. For example, for a 60 second clip of NTSC DV that takes 90 seconds to output, it would be (60 x 29.97fps)/90= (approximately) 20fps.
captainamerica77
on Sep 19, 2004 at 5:48:01 am
thanks no worries
captainamerica77
now why didn't I think of that
on Sep 19, 2004 at 5:48:29 am
D_
Re: now why didn't I think of that
by
on Sep 22, 2004 at 3:48:39 am
Funny, I had typed that into my previous response but then erased it as it seemed WAY too obvious. I was certain you wanted a super technical response!
KDaves saves the day with a common sense response!
Dylan
captainamerica77
on Sep 23, 2004 at 8:35:28 am
I actually did want a super technical way. but what ever works
D_
by
on Sep 23, 2004 at 12:29:22 pm
