Comment on the video editing setup I want to build
esky
by
on May 30, 2004 at 4:55:46 pm
All items are from http://www.newegg.com ... Basically I want to get an idea of which of these components will be best suitable for video editing in a new system.
ANTEC Life Style Series Black Case w/380W Power
Model# SONATA
Item # N82E16811129127
$ 95.00
Seagate 73GB 10,000RPM SCSI Hard Drive
Model# ST373307LW
Item # N82E16822111140
$280.00
Adaptec PCI-X to Single-Channel Ultra320 SCSI Card
Model# 29320A-R
Item # N82E16816103159
$208.00
MATROX G550 Video Card
Model# G55+MDHA32DR
Item # N82E16814106160
$108.00
ViewSonic P75F+B 17" PerfectFlat CRT Monitor
Model# P75F+B
Item # N82E16824116231
$164.00
Intel Pentium 4/ 3.2C GHz 800MHz FSB
Model# BX80532PG3200D
Item # N82E16819116164
$279.00
Intel "D875PBZLK" i875P Chipset Motherboard
Model# BOXD875PBZLK
Item # N82E16813121180
$130.00
Kingston HyperX Dual Channel Kit 184-Pin 1GB (512MBx2) DDR PC-3500
Model# KHX3500AK2/1G
Item # N82E16820144141
$301.00
M-AUDIO PCI Sound Card w/ MIDI and Digital I/O
Model# AUDIOPHILE2496
Item # N82E16829121103
$145.00
Lite-On Black 8X DVD+/-RW Drive
Model# SOHW-812S BLACK
Item # N82E16827106935
$86.99
Lite-On Black 16X DVD-ROM
Model# SOHD-167T Black
Item # N82E16827131118
$26.00
D_
Re: Comment on the video editing setup I want to b
by
on Jun 6, 2004 at 3:15:07 am
I only see one HDD in your setup. Recommend as a minimum, you have one Drive for the system files and another for video. Also recommend an IDE or SATA HDD so you can get more Gigs for your $.
For $280, you should be able to get two 7200 RPM 160GB drives and a third 80Gb for your system files...
