Frame Based ? Field Order A or B?
ucosta
on Oct 30, 2003 at 10:51:35 pm
I'm confused about the subject issue.
Have a Matrox 450 e-tv card with instruction saying to render in "Field Order B". I also have found that various DV capture programs capture "Field Order A".
Should I hence capture field order A and then render with field order B to record to tape?. Or what?
Any suggestion would be greatly appreciated. Thanks
Umberto in Milan, Italy
ucosta@iol.it
Jerry Jones
Re: Frame Based ? Field Order A or B?
on Oct 31, 2003 at 4:31:42 pm
One should choose the FIELD ORDER setting based on the capture device that was used.
For example, if one uses an OHCI compliant IEEE 1394 controller card for capture, then one should choose a FIELD ORDER A editing template.
On the other hand, if one uses an analog capture device, then one should choose a FIELD ORDER B editing template.
If one acquires video recorded by Panasonic player/recorders, then one should choose a FIELD ORDER B editing template.
The correct choice hinges on the capture device that was used.
Hope this helps,
Jerry Jones
http://www.jonesgroup.net
