Timer question...
phi501
Timer question...
on Jun 30, 2003 at 11:32:46 pm
I'm about to go on a week long trip and I would love to set my computer to record a nightly TV show. Is there any programs that let me set a regular time in which the program will start and stop recording?
ciabt
Re: Timer question...
on Jul 1, 2003 at 2:55:04 pm
Hi there
There are quite a few different programs that turn your PC into a PVR (Personal Video Recorder)and I will list a few of them, but you should check out them individually to figure out what features you need and which card is best for you. Here's a few of them:
Hauppauge's WinTV http://www.hauppauge.com/html/wintvpvr_datasheet.htm
ATI's All-in-Wonder Radeon
http://mirror.ati.com/products/multimedia.html
ATI product is the TV Wonder (USB)
http://mirror.ati.com/products/faqs/atitvwonderfaq.html#1
Snapstream Video Station 3
http://www.snapstream.com/Products/Products_PVS3.asp
Pinnacle PCTV
http://www.pinnaclesys.com/Category.asp?Category_ID=5&langue_id=7
Hope these help, most of these should be able to do everything you want them to do, and probably more.
Good luck!
Later
Brent
phi501
on Jul 1, 2003 at 8:02:26 pm
Thanks for the options...
I already have video capture device, I'm looking particularly for a program that will record a set time. Thanks for any advice.
ciabt
on Jul 2, 2003 at 10:38:18 pm
Hi there
Practically all the products I listed will record a set time. I think the Pinnacle product might be your best choice, you should check out the link.
Later
Brent
ciabt
on Jul 2, 2003 at 10:41:35 pm
Hi there
Check out the Pinnacle PCTV Pro:
http://www.pinnaclesys.com/ProductPage_n.asp?Product_ID=103&Langue_ID=7
Here's some of its main features:
High quality Stereo TV tuner for hyper band cable and terrestrial antenna reception
Record Stereo FM radio with real-time compression to MPEG audio and Microsoft® Audio (WMA) format
Digital MPEG VCR for TV - and video recording from Camcorder , VCR or DVD-Player
Real Time MPEG1-, MPEG2-, DV- software compression with presets for VideoCD, SuperVCD, DVD format
Direct Burn-to-disc of recorded MPEG-1 and MPEG-2 streams from the PCTV Vision capture library
Still image capture with digital image improvement from TV and connected analogue video sources via PCTV Vision and via TWAIN interface
Time-shifting feature lets you pause or replay while recording a live show
Multi-channel matrix and automatic channel name recognition
Easy-to-use timer for scheduled recording
PCTV Installation Assistant for quick and easy setup
WebText: Combines Teletext with the Internet and gives you instant access to all Teletext pages with convenient search engine and TOP-Text support
Highest quality still frame capture
