Curious About the DV Deck Hype..
COW Forums : Tech Talk
on May 12, 2003 at 3:42:14 am
I have a Canon GL-2 just got... have no clue how to really work it.. but basically I just hook it up to my firewire port.. my software mentions things about decks... what are decks... is there a purpose for them or would I just be wasting my money... and if they are of value any suggestions on where to get one and which one to get...
Daniel Rodriguez
Re: Curious About the DV Deck Hype..
on May 14, 2003 at 2:47:30 am
The "deck" reference is made because most professional NLE systems use a dedicated VCR or "deck" to capture from and record to tape. While you can spend anywhere from $800.00 to $2500.00 on a decent DV "spooling" deck, you're GL2 will do fine for now. However, using a deck will cut down on the use on your camera and make it more available as a camera instead of as a VCR which is what your essentially using it for when capturing and printing to tape.
Check out the "JVC SR-VS30U" and the JVC "BR-DV3000U". They're listed on the JVC website under Digital Broadcast & Professional Systems/Professional DV/ProDV VTRs
Good Luck!
© 2018 All Rights Reserved
