Is this system best for DVD authoring and editing?
NeedHelpBadly
on Apr 8, 2003 at 8:42:21 pm
Almost ready to purchase parts for my system - but before I buy anything, dooes this look okay -
Pentium 4 2.4 GHz
512 MB DDR333
WD 120 GIG 7200 RPM 8MB Cache
WD 40 GIG 7200 RPM 8MB Cache
Asus P4PE w/firewire
Canopus capture card
Also, I'm debating whether I should buy DDR now and save up for a real-time card for later - if this DDR memory would serve well for editing video and then exporting to DVD I would be pleased to know. I was told that RDRAM would only speed up the rendering process slightly, but wouldn't make a difference if I had a real-time card.
Thank you for your support and insight on this matter!
John Q
Re: Is this system best for DVD authoring and edit
on Apr 9, 2003 at 12:56:39 am
Before you buy your computer, decide on your capture card. Then check the card manufacturer's website and find out what hardware is compatible with the card. For example, no VIA chipset motherboard is currently compatible with the RT.X100.
