Will this system work for editing in Premiere 6.5?
fooshead
on Sep 27, 2003 at 3:39:50 am
I have been deciding between AMD XP (Barton) and INTEL P4 chips.
I have finally decided to go with a AMD XP 2600+ (Barton)
Asus A7N8X - Deluxe Mobo 400MHZ FSB onboard T10/100 onboard firewire, onboard 6.1 surround audio. Chip set is NVIDIA, ATA 133, SATA 150
Video card - NVIDIA GeForce FX5200 128MB 8x AGP DVI/ TV out.
Ram - 512 MB DDR
Master Drive 80gig Maxtor 8mb Cache ATA 133
Slave Drive 160gig Maxtor 8mb Cache ATA 133
DVDBurner
CDRW
Floppy
My question is I have the ADS Pyro Platinum Card with Premiere 6.5
Should I attempt to use the onboard Firewire 1st? or go ahead and use my ADS Card? If I use the ADS card will I have to disable the onboard firewire or can I leave it be? I am not for sure if it will conflict? Also is there any problem with the video card I chose? It does have DVI and I am not for sure if it will conflict?
I maninly edit home videos and what not and want to be able to put back to my Sony Digital 8 camcorder.
Here is a link to the MOBO http://usa.asus.com/prog/spec.asp?m=A7N8X%20Deluxe&langs=09
Thanks for any help.
