system setup
Charles
system setup
on Jan 29, 2003 at 5:45:14 am
I'm wondering how would one set up/or connect a system,like two hard drives(one for system os and programs and the other for capture clips),CD Rom Burner and DVD burner, without compromising each other?
For example, do I leave the sractch disk on it's own ATA-133 connector and let the system disk and the burners share the same cable? I just want to know the ideal setup for a configuration like this that will not hamper editing.
Charles King
Http://homebuiltstabilizers.com
John Q
Re: system setup
on Jan 30, 2003 at 4:08:23 am
It should work fine having one hard drive and one burner on each IDE channel.
Charles
Re: system setup
on Jan 30, 2003 at 3:16:56 pm
Thank you John for replying me. I was just concern about the data rate flow. I'm getting a promise raid controller later but just have budget for this setup at the moment.
Charles King
John Q
Re: system setup
on Jan 31, 2003 at 1:19:29 am
You don't need a RAID for DV editing and capture. DV is 3.6 MB/sec and just about any 7200 rpm ATA100 drive can sustain a minimum of 27 MB/sec.
Charles
Re: system setup
on Jan 31, 2003 at 8:05:14 am
Thanks. Good to hear.
Charles King
