pinnacle pro one with matrox g450 dualhead card
davebethlehem
on Jan 13, 2003 at 3:25:46 pm
I thought you would be able to spread the timeline over two monitors with the matrox card but I can't. Premiere and Pinnacle seems to allow only a few of the pop up windows to go over to my extended desktop on the other screen. How do you use Premiere with this card? Thanks for all your help.
alwayslearning
Re: pinnacle pro one with matrox g450 dualhead car
on Jan 14, 2003 at 2:30:40 pm
Good morning Dave.
I don't the know the differences between the 450 and the 550, but I have the G550 and it works perfectly with two monitors.
I am using Premiere 6.5 (it worked fine with 6.0 too) and two 19" Samsung Syncmaster 955DF monitors. The timeline and all boxes can be moved across both displays as though they are one.
The only thing I've seen is DVD's playing in a monitor window won't show on the right monitor.
If you still don't have it working and you've discovered that it should, let me know. I'll see what settings I can find and post them if they might help you out.
AlwaysLearning
