Getting Audio levels correct?
COW Forums : Tech Talk
on Dec 11, 2002 at 9:09:13 pm
Win98/MSPro5.1/Matrox RR-Mystique/
How do I go about making sure the audio levels are correct when I capture and play back clips?
Rainbow Runner has level adjustments when capturing, Win98 has audio levels also. Seems that when I'm editing a clip when I play from the timeline in MSPro the audio is lower than if I playback out ot Rainbow runner. I also have to set the Win98 Volume way down. Also I have some clips that I have to lower or raise audio levels in MSPro on the timeline to match other clips. I guess I'm capturing all sorts of levels. How do I make sure I capture and keep the audio levels correct?
Is there a file available that is "tone generator"? Maybe if I set everything with that I'll get it right.
© 2018 All Rights Reserved
