Will This Setup Work
COW Forums : Tech Talk
on Oct 28, 2002 at 4:09:12 pm
New to this process and want to make sure I purchase the right equipment. I am looking at either the Matrox RT.X10 or Pinnacle DV500 DVD. My system specs are as follows:
OptiPlex GX260T, 2.00GHz, P4, 400FSB, 512K Cache, Small-Minitower (I don't have the Small Form Factor or the Small Desktop model that lays down)
1.0GB, Non-ECC, 266MHz DDR, 2x512
80GB EIDE, 7200 RPM, ATA/100 Hard Drive
Windows XP
Integrated Intel Gibabit NIC, 10/100/1000
40X Max CD-Rewriteable, 2nd Drive
CD-ROM or DVD-ROM Drive:16X DVD-ROM, with software decoder
Sound Blaster Live! Value Digital 512V Sound Card
Additional Storage: 80GB EIDE, 7200 RPM, ATA/100 2nd Hard Drive
I read the technote here about trouble with some Optiplex systems and Riser boards (which if Dell informed me correctly, only appears in the Small Desktop Computer configuration). I just want to make sure that is the only known problem and if anyone can tell me if this setup will work?
Thank you very much for your help :)
© 2018 All Rights Reserved
