CAMCORDER
19BRENDA49
CAMCORDER
on Sep 4, 2002 at 8:38:11 pm
JUST PURCHACED A SONY CAMCORDER TRV340. TRYING TO DOWN LOAD TO COMPUTER WITH CD PROGRAM FURNISHED THROUGH IMAGE STATION; WHEN THE TAPE GETS TO ABOUT 18 MINUTES THE PROGRAM STOPS RECIEVING AND SAYS DATA EXCEEDS HDD. CONCIDERING I HAVE ALMOST 80 GB OF FREE SPACE ON MY COMPUTER THIS MAKES NO SENCE. ANY ONE TELL ME HOW I CAN DOWNLOAD CAMCORDER FILM TO EDIT IT. MAYBE ANOTHER PROGRAM? MY COMPUTER IS A DELL DIMENSION 8200 WITH WINDOWS XP.
JSUN
Re: CAMCORDER
by
on Sep 4, 2002 at 9:02:14 pm
You're hitting the 2 gig limit (this is normal). What software are you using again?
19BRENDA49
Re: CAMCORDER
on Sep 4, 2002 at 9:42:32 pm
PROGRAM FROM SONY SENT WITH THE CAMCORDER CALLED IMAGESTATION
19BRENDA49
Re: CAMCORDER
on Sep 5, 2002 at 1:50:48 am
IMAGE STATION
John Q
Re: CAMCORDER
on Sep 5, 2002 at 3:18:27 am
Check your drive format and make sure it's not FAT32. If it is, you need to change it to NTFS, which can be done by:
1. Click Start and Run.
2. Enter CMD and click OK. (This will open a command prompt window.}
3. In the command window, enter CONVERT /? and the Return key. (This will show you the syntax for the command.)
4. If you wanted to convert drive E, you would enter:
CONVERT E: /FS:NTFS
Under NTFS, the filesize limit is the physical size of the drive, although some programs will still limit the filesizes, because they assume they're writing to a FAT formatted drive. Then you have to upgrade or use other software.
