Audio Mixer - Datavideo VP-269 Tech advice needed
COW Forums : Tech Talk
on Aug 17, 2002 at 8:37:36 pm
I have an Audio /Video Enhancer/Fader unit, a VHS video machine and a PCI sound card. What I want to do is to use the mixer to route sound from a tape in a music center, through the mixer into the computer.
Well connecting up the above system produced no results.
Next I tried hooking up a camcorder Sony 10x, TV, Mixer, Video machine to see if I could add video to some footage I had in the camcorder. Here too I could not get a picture on the TV, as the operating manual mentioned I should.
The mixer specs are
Input / output impendance 75 Ohm
Output level Unity + .15 dB/ -0.5 dB
Frequency responce =/- -3 dB to 5 Mhz
Frequeny responce 20 to 18 Khz
THD Less than 0.05%
s/n Ratio 60 dB
Mic sens 73 0hm
Impendance Input 47k Ohm
Output 1K Ohm
Any suggestions will be greatly appreciated
© 2018 All Rights Reserved
