DVD compression Bitrate...
jlrd_1
on Mar 10, 2005 at 1:11:34 am
What is the best compression bitrate when exporting from the premiere timeline using matrox media export.
John Q
Re: DVD compression Bitrate...
on Mar 10, 2005 at 2:38:13 am
7 Mb/sec constant bitrate, which is the highest you should use for any DVD, as peaks can exceed this rate. If the total bitrate for the video and audio exceeds 9.8, the maximum bitrate per the DVD spec, the DVD player will choke. This gives you about 70+ minutes on a single layer DVD.
