problem copying dvd's
sprcar74
on Jan 21, 2005 at 2:37:07 am
i have a project that with the authoring done on DVDit PE. when i made copies and went through the entire encoding process, the dvd's worked great. got a new computer to do strictly editing work and loaded NERO6. using it to make copies, i have found that the copies are not working. i am using fuji dvd-r is there a better copying program or any suggestions. unfortunately the computer i had the project on originally crashed and i had to totally reboot and lost everything so going back to the DVDit way cant happen. any thoughts? thanks in advance
Scott
John Q
Re: problem copying dvd's
on Jan 21, 2005 at 3:16:34 am
Copy the VIDEO_TS directory to your computer. Then open Nero and create a DVD-Video project. Nero will then add an AUDIO_TS and VIDEO_TS directory to the project. Drag the original video's VIDEO_TS directory to the project pane. When you burn this DVD-video project, Nero understands what it is and physically places the files in the correct locations on the DVD to actually play on a DVD player.
