NTSC to PAL problem
natal
NTSC to PAL problem
on Jul 20, 2004 at 12:26:20 am
I have successfully completed and rendered several video projects with Adobe Premier 6.5. Compressed at high bit rate with Adobe MPEG Encoder and finally burned to DVD-R media through Sonic MyDVD. Playback and quality are perfect.
However when I repeated the process in PAL setting (for playback in Europe) video is OK except when there is a paned scene. The image is fragmented.
My first thought was that it was a field order issue but I made copies in Lower Field First / Upper Field First / No Field Order with little or no change to the video.
These are important videos that I would like to have PAL versions of. If any one has any suggestions with regards to solving this problem I would be most great full
Natal
Michael Autery
Re: NTSC to PAL problem
on Jul 20, 2004 at 2:51:47 pm
Are you using Premiere to convert the NTSC to PAL if you are that is where your problem is, you can't just have a NTSC video and change the settings in Premiere and have a PAL format.
You will need to convert the NTSC video to PAL format using ProCoder or another format converter.
Regards
Michael Autery
DVD-Makers.com A DVD Developers Community
natal
on Jul 21, 2004 at 12:12:31 am
Thank you Michael for putting me on the right track. I believe that may well be the problem
A Canopus ProCoder 2.0 which converts NTSC to PAL is in the price range of around $400 and $500. Is there a more viable alternative to converting my projects?
Thank you in advance
Natal
