Convert -x Audio Question
COW Forums : Tech Talk
on Mar 10, 2004 at 3:32:18 pm
Gary, thanks for your help before.
This is a followup question I have to the one I had earlier but dealing with 32KHz sound. I use edit dv with 32khz settings to do a print to tape. Now taking the analog footage from the camcorder into Convertx does it matter if it was originally 32khz sampling rate instead of 48khz? or does the fact that the camcorder is translating it to an analog signal really make the 32khz/48khz point irrelevant?
I think maybe the 48khz limitation is just on importing wav files into the authoring software correct?
© 2018 All Rights Reserved
