DVDit Error 'Unable to detect an ASPI Manager'
joharley
on Sep 28, 2003 at 12:01:25 am
When I have a DVDit project ready to burn to DVD and click on Build/Make DVD Disc... Some times I get the following error - Application error: (17235) Unable to detect an ASPI Manager
The only way I get around this is uninstall DVDit then turn right around and reinstall it. After the reinstall, it burns the disc fine?? But then the HP software won't reconize it's own DVD burner, (HP dvd200i). I reinstall the HP core software and it now works fine as well.
Any Ideas?
JoHarley
Michael Autery
Re: DVDit Error 'Unable to detect an ASPI Manager'
on Nov 20, 2003 at 12:38:08 am
I have had the same problem with DVDit for some time on Windows XP Pro, I have tried several ways to solve the problem, with no luck.
I usually just burn to the hard drive (make a folder) and use Nero, Prassi, to burn the disc, this is also useful for testing before you burn to disc.
But I now use Adobe Encore with no problems at all, I have deleted DVDit from my system, it doesn't have the features for a professional looking dvd, motion menus, motion buttons, etc.
Regards
Michael Autery
DVD-Makers.com A DVD Developers Community
Goodspeed
on Nov 20, 2003 at 10:34:28 am
I had similar problems running various Video / DVD applications until I installed a driver packet called ASPI layer.
If you need the drivers just email me and I'll send them to you. (W2K / XP only)
