Impression error: "It is exceeded DVD max bit
dragonfollower
on Jul 11, 2003 at 12:30:30 am
I'm getting the following error when I attempt to burn a DVD (muxing???)in Impression Pro:
"It is exceeded DVD max bitrate 10.08 mbps"
I think it's for the following file:
vts_1m19.vob
This may be for one of the menus, I'm not sure. But after a succession of errors over the last few days trying to get this thing to burn I am nearing my wit's end. I'd appreciate ANY help you can offer. There must be someone else who has encountered this problem.
Many thanks in advance,
-Brian
Jon Oransky
Re: Impression error: "It is exceeded DVD max
on Jul 14, 2003 at 2:09:49 pm
how long is the video you're trying to burn (total time)? What did you use to create your MPEG2 files? what bit rate did you select? check out http://www.videoguys.com/DVDauthor.html and read the section called 'DVD Tech tip: Exporting to MPEG2 for DVD Authoring in Premiere'.
- Jon
