Ulead WS - problem with wav files
pape
by
on Apr 6, 2003 at 9:19:50 pm
After editing video in Premiere I export video and became 2 files: MP2 and wav. Wen I import this two files in UleadWS I can't put them together in same Project. I can see the picture or I can hear the sound. Both - no way! Can somebody help?
Ron Evans
Re: Ulead WS - problem with wav files
on Apr 7, 2003 at 11:19:30 pm
Import the mp2 file to your WS project and drag onto the second box in the editing window( not first play), then click on the box that is titled "select a replacement audio file". A selection box will open, select your WAV file and your done. You will need version 1.3 to do this I think. IF you created a "system stream" from Premiere you wouldn't have this problem as the files will already be muxed together and WS will handle then correctly.IF you use the Adobe encoder click on the advanced settings , select multiplexer settings and select DVD. This will create a System stream.
Ron Evans
pape
by
on Apr 11, 2003 at 10:30:42 pm
Thanks Ron,it helps!
newguy
on Apr 28, 2003 at 3:21:19 am
You can only import and drag the mpv file into project, the audio you have to check on the left side use alternate audio option.
hope this help.
NG
