reversed fields order (correction)
COW Forums : Tech Talk
on Apr 6, 2003 at 6:19:45 am
Then I output my video to DVD.ever I use Top_field _first or top_field _second. on DVD player I see Both fields at the same time, instead of smooth motion. It's looks exactly like if you would play interlaced video on a computer screen - picture is striped
and fast motion is fuzzy.
I know for sure what video I outputting is ok.If take the same avi and record it to DV - everything is just fine. I trued Power Director and DVDit -result is the same.
anybody have a same problem?
Re: reversed fields order (correction)
on Apr 28, 2003 at 3:25:28 am
if you have tried both option then the problem would not be field order. :)
try to higher bitrate if this help.
Step more detail what you use and what the setting, process .... people can help.
Talking general like this no one know where the problem is, and no one knows if you get something wrong on process.
© 2018 All Rights Reserved
