Impressions Menu Audio Restarts
COW Forums : Tech Talk
on Jan 7, 2003 at 6:14:28 pm
Has anyone had problems with background audio in Impressions restarting every time a user highlights a different selection?
When I tested the DVD before burning it, it worked fine in Impressions. On my DVD player, the audio restarts every time I highlight a different option.
Could this be an incompatibility with my particular DVD player?
Re: Impressions Menu Audio Restarts
on Jan 8, 2003 at 3:41:42 am
It's not a problem with your dvd player, or with Impression. You are using true color menus, and the only way allowed with the dvd specs to have such menus is for Impression to essentially create a new menu for every button (behind the scenes). Every time you select a new button, you are actually going to a 'new' menu, and the audio will restart. It's best to simply use a silent audio stream if you are going to use true color menus. If you use highlight menus, then the audio won't repeat as you select different buttons.
© 2018 All Rights Reserved
