DVD Mpeg continuity
nickno
DVD Mpeg continuity
on Dec 8, 2002 at 10:51:50 pm
I have captured some film footage and have kept them below the 2GB limit in order that I can burn them on to a DVD as a backup. When I come to produce a DVD using Spruceup I am unable to find a way of making the program run the eight short films one after the other in a sequence. The only way I have been able to make the DVD is to put each film clip under it's own title and use a menu screen.
Is there a way round this besides using a program like Video Joiner, which I haven't had much luck with so far?
Nickno
newguy
Re: DVD Mpeg continuity
on Dec 11, 2002 at 10:55:12 pm
use DVDit! for many title in you movies
if you want to join mpeg files to one file then use tools like TMPGEnc to join them.
nickno
on Dec 11, 2002 at 11:07:48 pm
Thanks. I will try it out. I have only just started using TMPGenc so I will have to have a look into that one. I did try using DVDit, but after mastering Spruceup it seemed a bit confusing.
