DV Capture using Studio 7 vs. Premiere
bandjs
on Feb 19, 2003 at 2:25:28 pm
When capturing DV in Premiere I get dropped frames every minute or two. Studio 7 however, will capture a full 18 minutes without a single drop. Question: Do I sacrifice quality when capturing in a $100 as opposed to a $500 program, or is the quality the same with DV? Thanks, Bandjs
ciabt
Re: DV Capture using Studio 7 vs. Premiere
on Feb 19, 2003 at 5:33:47 pm
Hi there
You should be able to check in Studio 7 what your capture settings are and compare them with what you are capturing in Premiere. You might just need to change your capture settings in Premiere and it might capture fine! Also I would recommend defragging your hard drives before trying to capture. Good luck!
Later
Brent
