Drivers for capture card
tsorf
on Feb 15, 2003 at 11:32:42 am
I can't get the 1394 driver enabled to elimanate the "Texas Instruments" one. Also I get a conflict with the AV/DV driver, at least that was what showed in WinMe, I now have WinXP but still the same drivers are not installing and I can't find the IRQ listings now in either in XP, I'll keep looking but would appreceiate any help if anyone has had this problem. 800 Gateway Pentium3 with 512ram.
newguy
Re: Drivers for capture card
on Apr 5, 2003 at 4:56:44 am
usually firewire card uses plug and play driver from windows. If you can't see the card then it means the card is defected. Try other card if the same problem happen. 1394 card is very cheap, isn't it ? :)
