Project Size??
COW Forums : Tech Talk
Project Size??
on Aug 31, 2002 at 2:14:40 pm
I have a little under 2 hours of video on two files and used TMPGEnc to encode it to mpeg-2 at an average of 4400kpbs. The two files come out to a total of 3.70GB. I try to burn a DVD using DVDit, with a very minimal menu, onto a Verbatim DVD-RW 4.7GB disk and when it gets to the burn stage it tells me that it is too big for the Media. Is there a way to determine the approximate bit rate for the length of movie that will fit on the disk?
I was starting with a larger bit rate and DVDit would tell me right away that it was too large, and now that I have it down to this size it does not tell me until it is ready to burn. Very frustrating.
Re: Project Size??
on Sep 7, 2002 at 1:08:32 am
you can press "update" buton to see if the file is too big for the disk, before you finish the project.
any way I can usually put a 4.0 gig into a 4.7gig blank dvd(not using dvdit!), and play very well in stand alone player.
make sure you don't make double link, so the size of project getting double :)
© 2018 All Rights Reserved
