mpeg files
mickmason247
mpeg files
on Aug 23, 2002 at 3:29:41 pm
i have dvdit but when i try 2 drag my mpeg files it says no.Ive tryed a converter 2 mpeg2 but still no.should I stay with ulead videostudio 6 (but its very slow)or what can i try.(the burner it uses ulead moviemaker or something)
plz help
mickmason247
mickfmason@aol.com
Jon Oransky
Re: mpeg files
on Aug 23, 2002 at 5:37:03 pm
what are you using to convert to mpeg2? what data rate are you using? how long is your video?
- Jon x120
John Q
Re: mpeg files
on Aug 24, 2002 at 3:51:08 am
If you try to import MPEG2 I-frame video, DVDit will reject it, as it's the wrong format. The imported video has to be MPEG2 IBP for importing into DVDit.
mickmason247
Re: mpeg files
on Aug 24, 2002 at 11:45:41 am
Im using TMPGEnc plus2 and am selecting mpeg2.
So what should i use and what setting should i put it on so i can put it on dvdit.
mickmason247
mickfmason@aol.com
John Q
Re: mpeg files
on Aug 25, 2002 at 2:58:02 am
You might find this website handy for how to properly configure TMPGenc for DVD compatible files.
http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
