Make DVD machine duplicator
Valdir Souza Júnior
on Aug 17, 2002 at 4:48:25 pm
Is possible 4 DVD recorder in same machine ? (recording all at same time )
What the best program to record and controler 4 DVD-R ?
Nero, Esay CD, DVD Primo ?
I have Pentium III 1.1 ghz 256 Mb PC100
2 IDE chanel for 4 A04 DVD record and one promisse Raid to HD 40 GB 7200 rpm
This sistem work fine to duplicade DVD-R (video) ?
I'm need make 1000 DVD-R copy month.
Valdir
Brasil
newguy
Re: Make DVD machine duplicator
on Aug 18, 2002 at 3:45:31 am
"NO" for sure.
NG
John Q
on Aug 18, 2002 at 10:22:51 pm
If you were trying to copy CD's, then you could buy CopyCat software and do that, but I don't think anyone has offered the same type of software for DVD's.
The manufacturer of CopyCat does make standalone DVD copiers. http://www.insc.com/pages/dvdcopierLines.htm
stumpman
on Aug 19, 2002 at 10:47:06 pm
You might want to check this site http://www.caloptic.com They have both CD and DVD duplicator controllers. I have built both and as long as your source DVD's are not copy protected will duplicate just fine. In my case I have a Liteon 162 dvd reader and one Pioneer A03 burner and their dvd controller. Two speed is the best this will do. If you go to their site they have software as well to do multiple burns on a PC. They also offer good technical advice so send them your specific questions. No affiliation just a happy customer. I ESPECIALLY like their firewire products!
HTH, Stumpman
Frank
megaimpex
on Aug 21, 2002 at 3:58:07 pm
Hi !
I am using Instant VOB software for DVD Duplication , I am using P4 1.7 GHZ 256 mb Ram 40GB (7200rpm) with 3DVD writer.
leebo
on Aug 23, 2002 at 12:50:26 am
Both Nero (the latest) and Prassi can write to multiple DVD writers.
John Q
on Aug 23, 2002 at 4:59:32 am
Learn somthing new every day. Prassi came with my A03. I didn't know it could burn to more than one recorder at a time. It says that it can, though, depending on the system configuration.
It does recommend using SCSI host adapters when doing this, but I haven't heard of any SCSI DVD burners on the market other than the very pricey Pioneer S201, which only burns authoring DVD's.
Valdir Souza Júnior
on Sep 3, 2002 at 9:18:37 pm
I m look to Internet and ....
http://www.scsipro.com/catalog/pg19_firewirebridgeboards.htm
http://www.ioi1394.com/products/proddetail.asp?ProdCategory=FireWire_to_IDE...
transform IDE --> Fire wire ( use less CPU )!!
This is the magic !!!
One Fire wire card plug up 4 DVD-R !
Use 2 Fire wire card or one whith 2 channel !!
Valdir
Brazil
Laughing
