Dropping frames with GeForce3....HELP!
jrosnell
on Jan 20, 2003 at 8:28:51 pm
Hi all!
Newbie here....:)
What is wrong with my capturing when I get frames dropped on regular basis (about 2 frames dropped /second)...?
Been trying capturing with Premiere6, TVtools and virtual dub...The same result with each one of them.
Otherwise capturing is ok. (Analog from VHS and DVD)
I got:
WinXP pro
256Mb memory
80gb HD 7200rpm (WinXP on C: D&E for capturing)
40gb HD (tried to capture to this HD too, no difference)
GeForce3 (Asus V8200) Tv-in/out
AthlonXP1700
PLZ help!
J
jrosnell
Re: Dropping frames with GeForce3....HELP!
on Jan 21, 2003 at 6:32:53 pm
OK.Found out what was wrong.... VIA 4in1 drivers!
Updated 'em with the newest (HYPERION 4in1) and NO dropped frames anymore. :)
wadek
on Feb 18, 2003 at 3:17:35 am
I strongly recommend Windows 2000 Pro. Everything seems fine.
I was never a fan of GeForce video capturing.
Kenneth Daves
on Feb 18, 2003 at 12:47:36 pm
XP is not your problem.
What are your capture settings? If you are capturing Mpeg 2, try lowering both the audio and video data rate. I was never able to get acceptable quality Mpeg using the ATI All-In-Wonder 128 Pro except by lowering the video data rate to about 4000Mbits/sec. Even then, I tended to lose AV sync.
If you are capturing AVI, what is the codec? ATI's AVI codec's in Windows 2000/XP have huge data rates that overwhelmed my drives.
