Avid Xpress Pro- install on video drive?
chuk
by
on Jan 5, 2005 at 6:01:33 pm
I have an 80GB system drive and a 250 GB video drive... during installation, Avid asks if you want application data installed on c: or the secondary video drive. Does anybody know if you can even install and run correctly on the secondary drive? And if so, does it run faster installed completely on the system drive and just saving project files to the video drive OR by running the whole thing on the video drive?
thanks in advance!
Jobiwan
Re: Avid Xpress Pro- install on video drive?
on Jan 6, 2005 at 8:29:09 am
Install your application DATA on the 2nd (video) drive, but install the application (Avid Xpress Pro) itself on the 1st (system) drive.
You could install and run on the secondary drive, as in it would be physically possible, however it would be very much NOT recommended.
Definitely, yes.
does it run faster . . . by running the whole thing on the video drive?
NO
HTH Cool
