Premier Pro transition error
baima
on Sep 16, 2004 at 9:46:21 pm
This is a strange one, I have moved from Prem 6.5 to pro, after i have edited in the time line then add a transition when previewed part of the unedited clip apears through the transition.
Anyone any ideas
Cheers
D_
Re: Premier Pro transition error
by
on Sep 17, 2004 at 2:38:25 am
Can you be more specific. Without looking over your shoulder, I am not sure what your actual problem is.
Marc Peters
on Oct 15, 2004 at 11:35:00 pm
Remember that when adding a transition, footage is "overlapped" from clip A to clip B. What you are seeing is a few frames after your edit point in clip A and a few frames before clip B. Simply move the edit point of A in!
