Rendering in MSPro7 - audio breaks up?
captaincrunch
on Jul 21, 2004 at 12:17:27 pm
Rendering in MSPro7 . . . after several seconds into the rendered .AVI file the audio begins to cut out and break up, only peaks are recorded.
I have the ATI AIW/radeon 9000 card . . . is this an inherent problem with this card? Is there a fix or tweak? Or is it simply a case of "you get what you pay for?"
D_
Re: Rendering in MSPro7 - audio breaks up?
by
on Jul 24, 2004 at 1:40:21 am
CC,
You said that you finally got to capture fine. I see you still have the AIW card in your machine.
You say you have problems after rendering. Are you rendering to an .avi file?
How many hard drives are in your system?
Are you planning to get rid of the AIW card? As Gary mentioned, it will only cause more headaches for you. Find a replacement!
captaincrunch
on Jul 26, 2004 at 11:57:38 am
Yeah, yeah, I know . . . but money's tight right now and that was all I could do. Soon.
Anyway, P4; 2.3g; 512k; 4gHD(system); 20gHD(video).
Yeah, weird . . . I rendered to an .avi file, only 3-4 min worth, and the audio began to break up. BUT! last night I rendered the entire 24 min project and it did fine?!?! I dunno . . . .
I've got another problem with DV to tape via timeline where I get glitches.
I'll post it new.
