Ulead MS pro 7 crashing
stillboardin
on Jun 5, 2004 at 3:46:25 am
I need some help. My MS Pro 7 just started crashing as soon as I try to open a video file to place in the editor. In fact it is happening with video capture and any other video program I work with.
This just started happening within the last few weeks.
My system is a Dell Dimension 8250 P4 with 256M of ram 80gig hard drive.
Like I said before, 2 weeks ago I had no problems and I don't believe I changed any settings on the computer.
Has anyone else seen this?
D_
Re: Ulead MS pro 7 crashing
by
on Jun 6, 2004 at 3:01:24 am
If I open a video project, click on the video clip, and then try to use the jog dial on the Source Preview Window, My system will INSTANTLY reboot! Otherwise, it appears to run normal.
Previously when I had problems with MSP 6.5, the service dept suggestion was to uninstall and reinstall. That helped one of my bugs.
Good Luck solving your problem.
(Are you running short of drive space?)
