Exporting AVI problem
amigo
on Mar 3, 2004 at 5:34:22 am
im using Premiere 6.0 ... capturing From DV sony handycam,after editing .. total size of the file AVI is around 5 Gig. Im finished and want to EXPORT it ,so i click - (export timeline - movie)
setting for General-file type is microsoft DV avi
range- entire project
Video-microsoft DV NTSC
The output is ok and playable, but one thing bugs me. the last part of clip is not taken :0
let say 45 minutes is total clip, the Final output is 40 minutes
any misconfiguration i have done? need some advises
John Q
Re: Exporting AVI problem
on Mar 4, 2004 at 4:49:16 am
Are your exporting to a FAT32 formatted hard drive? FAT32 hard drive have a filesize limit that NTFS doesn't.
amigo
on Mar 4, 2004 at 1:05:22 pm
thanks for the reply. yupz im using FAT32, Wats the limit of FAT32?
but if im using other software like ulead videostudio7 ...is ok,but lack of tools...dats y i like more adobe premier :)
hmm.... could it be some configuration or setting problem?
John Q
on Mar 5, 2004 at 5:19:06 am
Some software gets around the FAT32 filsize limit, typically 2 GB, by using a software driver that automatically splits your video into hidden 2 GB chunks. The real solution is to use NTFS formatted hard drives and turn the software splitter off, if possible. A command windows utility, CONVERT, will convert your FAT32 formatted drives to NTFS without losing any data.
Open a command window by clicking Start, Run and enter CMD. Then enter:
CONVERT /?
to see the syntax of the command.
For example, to convert drive D, you would enter:
CONVERT D: /FS:NTFS
