problems with exporting in Premiere
COW Forums : Tech Talk
on Feb 16, 2004 at 9:51:15 pm
My system specs:
Windows XP pro
ASUS V7700 DeLux (G-force2)
AMD thunder-bird 1.4G
512MB ram DDR
Premiere 5.0
i got the following materials on a CD:
1. a movie compressed using Elecard MPEG2 Video Decoder(704*576).
2. a movie compressed using MPEG Video Decoder (522*288)
when export a movie (with both) the final movie looks like a big jump-cut, and with no continuous movement of the frames.
i've tried to export the movies using the compression of any of those compressors: Microsoft Video1, DivX Mpeg4 Fast motion, DivX5.1.1 codec , and i got bad results with all of them.
the source materials looks 'ok' (VHS cuptures) when running out of premiere - so what do i need to do in order to get a nice and continuing movie?
any answer will be appreciated!
Re: problems with exporting in Premiere
on Feb 23, 2004 at 9:31:13 pm
I recently had a similar problem. I couldn't export from the computer back to the DV camera. I tried everything, and it turned out to be a problem with the firewire card. When I replaced it, everything worked fine.
You might see if you can borrow a card, and switch it out.
Randy Tennison
Stonewall Productions
© 2018 All Rights Reserved
