Stuttering after exporting in Premiere 6.0. Help!
Paul Wasserman
on Dec 12, 2003 at 11:26:22 pm
Running Premiere 6.0 on an XP platform (AthlonXP 2500+, 1gig RAM, Radeon 9800 Pro) using all DV.
If I export a movie in either Quicktime or AVI, regardless of the compression used (I prefer DV codec), I get bad stuttering on playback IF I export at 720x480 *AND* my clips have effects in them (in this case, all my clips are set to 50% speed).
If I export at 640x480, only the bottm half of the playback stutters.
If I export at 320x240, no stuttering whatsoever.
If I export at 720x480 with no effects (i.e. clips are all set to 100%), no stuttering at all.
I should mention as well that timeline playback is flawless in all scenarios; this is only happening when I export.
Please help! I am doing videos for Xmas cards.... :0
TIA!
Paul
