Load from stream error Videostudio 7
Bandit
on Nov 30, 2003 at 2:34:57 am
Has anyone fixed the "load from stream error" in Videostudio 7? I've been using this program since May and this just happened.
Jerry Jones
Re: Load from stream error Videostudio 7
on Dec 1, 2003 at 9:18:29 pm
Although it references version 6.0 of VideoStudio, there is a reference to this particular error message in ULEAD's Knowledge Base:
http://support.ulead.com/kb/0003/KB1348.htm
>Problem:
>When I launch VideoStudio 6, this
>error message appears: Load from
>stream error. What should I do?
>Error Message:
>Solution:
>1. Erase the contents of
>C:Windows(Winnt)Temp directory.
>2. Uninstall VideoStudio 6 from
>your computer. Control Panel > Add/Remove Programs.
>3. Re-install VideoStudio 6.
>4. Download the VideoStudio 6.02
>Update Patch including CD/DVD Burning
>Patch from our Web site at
>http://www.ulead.com/tech/vs/vs_ftp.htm.
I would follow the same steps as indicated for your version 7.0 of VideoStudio, EXCEPT:
1. I would recommend that you INSTEAD install the UPDATE PATCH for Ulead VideoStudio 7.0 on the Web page at the following link:
2. I would also recommend that you INSTEAD install the following CD/DVD BURNING PATCH:
ftp://ftp.ulead.com/pub/Updates/DVDPlugin1.0/030815/DVD_PLUGIN_Patch_E_0308...
Hope this helps,
Jerry Jones
http://www.jonesgroup.net
