what is the best way to do this???
oosal
on Apr 29, 2003 at 12:20:32 am
Okay say i am creating a lengthy video with several different parts, i am using premiere so should i A>Make several different projects to do the different parts and then put them all together at the end, or B>Do it all on the same timeline? What is the best way?
Thomas
Ron Evans
Re: what is the best way to do this???
on May 1, 2003 at 12:32:15 am
If it keeps your mind clear create multiple projects and then create a final Premiere project by importing each of the seperate projects( File>Import>project). This has the advantage of allowing you to make lots of changes on each project without the chance of messing up the other projects!!! Only put it all together when you are satisfied with all the projects individually.
Ron Evans
oosal
on May 1, 2003 at 8:35:11 pm
Thanks much ron i appreciate the advice. Any plugins for premiere that you think is a must?
