Premiere 6.0 and preview window
Scott Cape
on Dec 26, 2002 at 10:19:55 pm
I want to know if there is a way to get the preview window to run outside the Premiere Window. I run 2 monitors. What I would like to accomplish is to run the preview full screen on my 2nd monitor. Has anyone else done this successfully or have an easy alternitive?
Scott
grinner
Re: Premiere 6.0 and preview window
on Jan 2, 2003 at 12:34:52 am
use an NTSC monitor for previewing/playback and your duel monitors for workspace.
grin
http://my.cybersoup.com/grinner
newguy
on Jan 10, 2003 at 12:34:48 am
I use a 14 inche TV to review, when editing video
videoblaze
on Jan 31, 2003 at 2:07:00 am
Does your video display card have a TV out port? If not, you could try double-clicking on any clip in the timeline to get it to play in a full sized clip window. You should be able to drag the clip window into the desktop area that is mapped to your second monitor. Your are correct, this idea won't work if you have applied effects or have compositing video layers.
You can export the timeline to create a .avi, .mov, .rm or format you prefer, then play the clip by double clicking on it the project bin (you need to import the video).
Just a couple of ideas for you.
