Capture problem
d2000etc
Capture problem
on Oct 23, 2002 at 1:32:07 am
Im having a problem with dropping frames during DV transfer in Premiere 6.0 On WinXP Professional, PIII 1Ghz, 512 RAM, 2 seperate hard drives 40 gig for system 80 gig for video storage, ATI All in Wonder 128 AGP Capture Card. DMA is enabled and have been to every adobe forum. What am I doing wrong?
John Q
Re: Capture problem
on Oct 23, 2002 at 2:48:00 am
Is your video drive on IDE channel 2? If it's on the same IDE channel as your boot drive, Windows will interrupt your transfer to talk to the boot drive. Only one drive can use an IDE channel at a time.
d2000etc
Re: Capture problem
on Oct 23, 2002 at 10:37:18 pm
How will I know?
John Q
Re: Capture problem
on Oct 24, 2002 at 4:36:27 am
Most bios display the IDE drive configuration during boot up. Otherwise, you'll have to open the case and see if your hard drives are both on the same cable.
