Transitions and Slow Motion Setup In Premiere ???
newguy
on Jul 19, 2002 at 3:09:35 am
Hello Everyone,
I would like to ask if we can set up the transitions (or add a new transition chanel) so we can make a transition effect between 2 graphics tracks (example : Video 3 and Video 4).
If yes, could anyone please give me a tip.
Another question about slow motion, I apply slow motion but the result is bad (motion not smooth). Could anyone give me an advice.
I'm using RT2500, NTSC system.
Thank you all.
NG
selby52
Re: Transitions and Slow Motion Setup In Premiere
on Jul 19, 2002 at 3:52:56 am
Video slow motion will never look as good as slow motion in film. However, I find that if you apply "frame blending" that it tends to make the slow-mo look a bit nicer. To do this, right click on the video you want to apply it to, go to "video options," then "frame hold." There at the bottom of the frame hold options box you will see the "frame blending." Check it and see if it is to your liking. Hope that helps some.
newguy
on Jul 19, 2002 at 12:42:07 pm
Thank you bro.
Have a nice day !
NG
